How to extend doorbell button cable?
Discussion in 'Electrics UK' started by Techboy, 30 Jun 2021.
  1. Techboy
    Techboy
    14 Sep 2005
    39
    Thanks Received:
    Buckinghamshire
    Country:
    I'm going to fit a Ring doorbell, so need to extend the doorbell button cable that has previously been cut. There isn't much currently available...
    I have tried pulling it to see if it will extend a bit, but it won't.
    What's the best solution please?
  2. AndyPRK
    AndyPRK
    4 Jan 2009
    5,931
    Thanks Received:
    596
    Herefordshire
    Country:
    The only thing that will work there is soldering and heat shrink
    after careful stripping
  3. Sponsored Links
  4. JohnD
    JohnD
    15 Nov 2005
    75,030
    Thanks Received:
    4,350
    Crossgates, Europe
    Country:
    Cook Islands
    surely you can get to the cable on the inside, and joint a new bit on, and poke the new wire through?
    was it cut by a vandal?
  5. Techboy
    Techboy
    14 Sep 2005
    39
    Thanks Received:
    Buckinghamshire
    Country:
    Okay, I'll do this. Thanks.
    No, I think it was done by the previous owner of the house when they fitted the wireless doorbell.
  6. Sponsored Links
  7. sparkwright
    sparkwright
    20 Aug 2009
    8,949
    Thanks Received:
    1,128
    Dorset
    Country:
    You could try making a hole somewhere else where you think the cable may run, to gain a SENSIBLE amount of slack cable to joint to.
    Good luck with trying to solder onto that little bit of cable...
    • Like Like x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
