If there's a cut end visible, 22mm stuff is a rattling good fit but a 3/4"
olive works just fine.
If I'm not sure, I use a caliper or vernier gauge so that I've the correct fittings ready.
I've noticed that some of the 3/4" compression fittings have an octagonal nut, but that may be just local to here.
John
You could use an adjustable spanner as a caliper to compre it with a dog end of pipe of known size. Set it to a snug fit over a bit of 22mm pipe, and it will rattle about on a 3/4" pipe. Set it to fit a 3/4" pipe, and it won't fit over a 22mm pipe.
If you’re using compression fittings you can get 3/4" olives. They will fit all 22mm compression fittings; elbows, couplers, tees etc etc .
If soldering you can get metric to imperial couplers in end feed and solder ring.
Speedfit do push-fit imperial to metric couplers, too.
get a 22mm fitting from a diy shop, stick it on the end, if its a nice snug fit, its 22mm, if its loose then its 3/4, if its very loose then its neither.
