How to join tongue and groove at angle?
5 Feb 2007
Hi
Working on a camper van conversion.
I’m using wickes 8x94mm tongue and groove interior cladding to do the ceiling. I want to bring one panel down at the sides but at a 45 degree angle.
Looking from back doors into the van it would like this ... (although this is upside down)
\____________/
any ideas how I do the end bits.
Is there a way I can connect the full length at an angle? Internal flexible angle or something I can put between two panels?
many thanks.
Rip (circular saw) a bevel onto the edge of the upright bits (at the appropriate angle), or hand plane to get the same (sliding bevel recommended to check, either way) then fix these two pieces to the base by pinning through the backs. This does mean that the outer edges (a sort of off right angle L-section) will need to go in first and last in the installation. Recomend that the upright bits are fitted with the geoovecedge towards the floor bit , regardless whether they are fixing to a tongue or groove edge
