This is the job of the builder but I want to make sure he hasn't missed anything. Its the first time I have had any building work done in any property I have lived in.
The wall is a single leaf internal brick wall supporting the floor and wall above. I believe the wall above also supports the ceiling joists - the loft is not habitable and is empty
He has suggested the following
1.1500mm span to use 1800mm concrete lintel 100x 145 is the R15a orientation (this has been confirmed by the lintel supplier)
2. Use 4 acro props spaced out no more than 1m apart and Timber needles as well as Timber support for props which will be on solid wooden floor.
3.The lintel will be placed on bedding mortar (4:1 mix) and if required engineering brick - padstone is not required.
4. Once the lintel is placed on bedding mortar to leave it a day to cure. Then to mortar up the gap above the lintel - about 10mm with a 2:1 mortar mix.
5. Leave the mortar another day to cure again before removing the acro props and then cutting out the bricks below.
I have seen online that some people use slate as packing? Why would you need packing. I have some old blue slate from my roof - could that be used for packing or is there a special kind for lintels?
