EPDM is a rubber sheet that can be glued to ply. You then need flash form for the edges and joins, this will last forever. Recommend Firestone rubber cover. This is what we use.what is EPDM?
thanks in advance guys.
http://lmgtfy.com/?q=edpm+roofing
Ok now, I don't know if this job is for you....if I was you I would get a tradesman to fit this. Fire means it's should be heated with a blow torch (not the one you use for plumbing) before being stuck down as it's melts the adhesive allowing it to stick. I would not recommend using this felt with "glue"!!!! I wouldnt recommend u do this alone. Just get someone in. Otherwise your pyramid could turn into an ' ancient ruin'!![]()
Since you don't want to take the advice, crack on, do want you to do! I ain't the one getting wet! Good luck!
FYI good luck getting the 'glue' to stick on the vertical.
what i dont know is what type of glue and nails to use,
