Thanks. I am going to give it a try.
I am not sure about the bayonet type fitting. The replacement starter has what looks like two small screw heads. Is that it please?
Thanks for help.
JamesEB
Did you try swapping the starter also to another working fitting.
It would be an expensive call out for just a starter, where in uk are you
What starter did they send you, some places aint got a clue, i would check they aint sent you a series starter in error
After he had left, my wife who is not to be tangled with would not believe that the fitting had failed. She went off and got another starter and she fitted that and voila it works perfectly.
JamesEB
Well done to the wife![]()
If you like the fitting then most internal parts are still obtainable, may cost more, but sometimes better than odd fittings.
As for the starters some new ones do fail, i find there more fragile than they appear and often get mishandled, so hope youve solved it
Is she from Yorkshire? They can be scary!![]()
