I have taken off the old tiles from our plasterboard walls... Which created lots of damage to the board... I have replaced the boards which were too badly damaged and now I am left with the lower sections which only have patches of missing skim (back to the plasterboard). These areas range from 20mm x 20mm to 300mm x 200mm in size (skim is 2mm deep approx)
I would like to fill these areas to make the walls reasonably even.
Can anyone recommend a produce to use?
Someone one did mention using adhesive others say just plaster. Basically I want something which is not going to pull off the wall when the tiles go on!
