K
Klaus_K
Not sure if this counts as electrical work, but I figure this is the best forum to ask this question.
I have a one-way light switch, where the mounting screw was stuck in the screw hole on the box. Removing the screw completely ripped up the plate, so I now only have a screw socket on one side. Ideally, I'd like to remove the old mounting box and replace with a new one.
I'm happy to rip the old box to pieces to prize it out of the wall, but I'm not sure how to put a new one back in its place. The hole in the wall is tight around the box with brickwork and plaster. To make things even worse, there is tiling around the hole, which overhangs the box.
Can anybody suggest a tool(s) for cutting back the tiling by a faction of an inch and enlarging the plastered/brick hole which contains the box. I guess that the tiling cut would need to be pretty clean, since that would be visible, but it doesn't matter if I take back a bit more of the plaster/brick, since that will be hidden by the tiling.
