So if yo don't screw the toilet to the floor, what do you do to disguise the holes?
I would only ever screw it to the floor. If it was tiles with ply underneath, go through the tile with a 10mm tile bit, then secure the toilet using 40 or 50mm no5 or no6 brass screws, then plastic caps over the screw tops
In our house the toilet cistern was being held to the wall by the 2 pipes coming in the bottom, and the connection to the floor part, so when you pushed the flush down, the cistern rocked. Was great fun drilling holes through the cistern fixing holes into the block wall. Was praying that the cistern didn't crack, as the drill fit was touching it due to the angle of the drill!
You put two dobs of White silicone over the holes, spray, and smooth off
I was not a diyer but was a bathroom installer. I was paid many thousands of pounds to fit lots of wet rooms and bathrooms. If this was a bodge or looked naff I would never have got paid.
You can screw it if you want, this is just a different method that works.
You would not be able to move the toilet, which is the point, whether it is called silione or not, maybe I could rebrand some, super toilet pan fixer then everyone would be happy
Until you need to remove pan in order to clear blocked soil pipe......then you have to remove old silicone and redo.
I still use fixing screws with cover then run sealant around pan for neat finish.
Also a basin still need to be screwed to wall as silicone isn't enough to hold in case a kid tried to climb up.
If a toilet or basin has screw holes, still need screws.
