How to stop drill from drifting when drilling dot and dab
16 Jan 2009
Avon
When drilling through dot and dab into the external or party walls, I find the drill can drift quite dramatically once it hits the masonry meaning the resultant hole is in the wrong place. How can I avoid this happening? I have a battery or mains hammer drill available to me and I'll get a new bit in the morning in case that's the problem. This is a 10mm hole for use with Corefix and the house is about 13 years old (I don't know exactly what blocks are used).
Plus, use a smaller drill bit first, go slow into block behind. Then use the bigger drill bit...
(And accept that if you go through the plasterboard and end up hitting the edge of a brick, the bit is going to wander into the mortar)
Put a small bit into the battery drill and use that first
(If your drill bit is long enough and you have the space)
Bit of scrap timber (pallet plank works) a foot long, 2 or 3 inches wide.
Drill a hole in it same dia as your masonry bit
Hold plank against wall (1 hand or a friend)
Drill through hole.
This also works using holecutters in ceilings (for downlights etc)
If your friend's a plank do you drill through them?
Good call; I'd once drilled a hole too small for a downlight but this lost my centering hole to keep steady for wrapping the smaller hole with a larger one. It kept snatching when trying to start on an angle, but zapping a hole in some scrap timber using the hole saw I wanted to use on the ceiling meant I could use the timber to hold the hole saw steady..
Drill through hole.
I use a similar process for drilling through porcelain tiles with diamond core bits. Sometimes I use a hot melt glue gun to hold the scrap of timber in place. A tap with a hammer after and the timber falls off the tiles.
Glue guns are great for those kind of jobs. A few blobs of hot melt glue will lock the timber in about 10 seconds, leaving you free to use both hands for the drilling.
One of my local bathroom shops uses hot melt glue to mount all the tiles in their demonstration displays; I thought it was a fantastic idea for non-service work, especially as it's possible to strip the tiles out again with little fuss and mess.
