Hi
I have multiple chemical sensitivities and have a bit of a situation. Basically I live in a flat and the 'inside' of my flat is friendly with me. However recently without my knowing some painters came and just painted the little block surface underneath my windows. As a result if I open the windows all the paint fumes come in and make my entire flat unbearable.
Now this can easily be solved if I simply place something over the small areas that makes the surface underneath the window. I am on a high floor and nobody can notice if I cover it up. I am thinking maybe I should cover the surface with ducktape or something however WILL THIS prevent the fumes from coming up??
If not duck tape can you suggest something else? I just want to cover the surface outside the window so as to prevent the fumes from coming in when the window is open.
