Read
this best practice guide it does give some pointers, pages 7,8 and 13 show pictures of rubber insulated cable and the problem as it degrades.
Some of the things we are told to look for don't always make sense, I have seen where the grommet is missing, however the plaster is holding the cable in such a way it could not possibly cause a problem, so it is not always cut and dried.
When mothers house was rewired, after some of the old sockets that used PVC cables were reconnected, so some one may assume this house has been rewired and all is good, but can still be some odd bits, where for example the out house was wired using conduit in the concrete and really hard to rewire, so old wires used.
The IET does
model forms down load them and try filling them in, there will be bits you can't do, but last but last 2 pages should help, it also gives you an idea of what an EICR is all about.
Most of the time you look at an old house and think to be on the safe side it needs a new consumer unit (also called fuse box or distribution box) so RCD protection can be added, what is hoped is once that is added the installation will fail safe, so start with picture of the CU, see what people on here say, if it is needed then likely the electrician fitting it will give you some report on the state of everything else.
