Well, I suppose I should thank you gentlemen for at least bothering to give answers of a kind. I can assure you though that in my case my engineer exists (and was not that cheap). He is of course a man of mature years, although the boiler had only limped just past its two-year guarantee.
Perhaps the question about the fan is more a hypothetical one than a real repair question, in that it would be interesting to know why it failed I haven't tried any testing yet, but the PCB isn't showing any visible signs of damage and does not seem to have been affected by water. Doubtlessly there are various electronic components on the PCB that could fail. In my limited experience (more in the domain of amplifiers etc. I admit) electrolyte capacitors are among the least reliable of components. I see most of the bits on this PCB are the newer surface mount technology, which is usually pretty reliable, but it does have several old style caps and an IC. If it is not secret knowledge, what components do you find are the most common cause of failure?
Incidentally the information about the readings on the terminals would not help do a repair but only tell you if you had succeeded and the device was now showing the right values. Remember I would not have been in a position to test it in a boiler.
Anyway I will leave you in peace.
