Then in that case sorry but you can not adjust the pump speed it MUST be on the factory setting in order for the boiler to operate correctly, have a read on here about balancing your system , this might reduce any noise issues you may have
I thought you could change the pump speed on d19 on the ecotec plus depending on system load ? as its a combi I cant see the system being that big, (although you never know)
How do you measure the tempeature of a radiator?
So, across the whole house, radiators should not differe in temp by more than 12 degrees?
At the moment, they all have the thermostatic valves turned to full.
