how to turn pump speed down?
30 Jul 2006
How do you turn the pump speed down on a boiler to stop the whistling sound in the radiator pipes?
Then in that case sorry but you can not adjust the pump speed it MUST be on the factory setting in order for the boiler to operate correctly, have a read on here about balancing your system , this might reduce any noise issues you may have
I thought you could change the pump speed on d19 on the ecotec plus depending on system load ? as its a combi I cant see the system being that big, (although you never know) :roll:
Yes, if you read the instructions with the boiler.
However, I would suggest you check the balancing first because its not normally necessary to do that.
How do you measure the tempeature of a radiator?
So, across the whole house, radiators should not differe in temp by more than 12 degrees?
At the moment, they all have the thermostatic valves turned to full.
