How Tom connect new rads in loft conversion back to existing system ?
25 Sep 2017
Hello. New here and this is my first post.
I have almost completed a loft conversion in my own home. All pipework and rads are in place. Soon I need to connect up my new plumbing to the existing flow and return pipe stubs ends coming up from downstairs.
My question is :
How do I get the pressure out of the existing system, in order that I can remove the speed fit stop ends currently on the flow and return pipes ?
I do not want to drain down the whole system - just remove enough pressure so as to stop getting my hands wet up in the new loft. !
Advice would be gratefully received !
20 Jul 2005
Nottinghamshire
First of all, you need to tell us what type of system you have, and how it is pressurised. Is the boiler fed from a storage tank. Something like this:
shopping
Or is it a system boiler that has to be pressurised manually by opening a valve and watching a dial / display until the operating pressure is reached, something like this:
images
25 Sep 2017
Thanks Stem. It's the second pic. A Combi boiler. - A Glowworm. Meant to state that in the original post.
20 Mar 2009
Potters Bar
Isolate an upstairs rad or towel rail.
Put a tray or rubble sack underneath one of the valves.
Crack the union nut or 1/2" nut that goes from valve to rad/rail.
Allow rad water to dribble into tray or bag. Tightening nut back up and emptying full tray or bag into a bucket.
When rad empty, tighten nut and open valve - water from rest of system will flow in and reduce system pressure.
Or you can use a downstairs draincock (if present) to remove a bucket or two of water!
Or use the drain valve on the boiler.
