I am trying to fit this lovely 'spout & stops' mixer for the new bath:
It's from Hudson Reed, code BC309, and just comes with the bits shown, no pipes or valves etc are supplied. But there are some problems.
The thread at the end of the spout is only about 33mm and my builder reckons that it will be hard to mount it effectively as he needs more length on the thread in order to fit the plyboard, plasterboard and tiles between tap and nut.
I have read that metal plates can be used to brace these sorts of fittings, but do such plates exist for a 3-hole solution such as this? I can find none.
Any help appreciated. It is going in a stud wall with about a 60mm cavity between the plasterboards.
Thank you for reading
Benefact
Benefact
