I have a leak . . . . . what's this . .???
Thanks. It seems to be coming from under the white thing with "hot water", "heating" arrows.
Are you sure it's leaking from the valve and not that crappy pushfit/flexy abortion beneath it?
I take it you mean the grey and white things to the right. It's possible, definitely. Really difficult to check as access is really difficult. I had to lean over with the camera to take the photo.
Slide a kitchen towel between the white valve and the copper pipe below it. Also, slide a kitchen towel under the copper pipe. That well then help establish the level of the leak and help pinpoint the source.
I agree with Sooey - there is a lot of verdigris around the gate valve body suggesting water leakage at some stage.
Rather than normal kitchen towel, can I suggest you use the blue workshop type paper towel. This offers the advantage of patently changing colour at the slightest sign of water
I would not be surprised if the valve was leaking from the spindle. Very common on this make of valve.
