I have just had my oil tank refillled after coming back from holiday to find it dry as a bone.
Assuming I havent wrecked the pump (which I gather is a fairly strong possibility) how do I get the system started again?
It is a Trianco Eurostar boiler.
I havent been able to positively ID a pump - as I thought bleeding that would be my first port of call. There is a small brass coloured round item attached between the oil pipe coming through the wall & the boiler casing.
I cant read the label as it is mounted facing the wall. It has a black knob on it. As I cant see the label I cant check online to find out if a, it is a pump & then b, how to bleed it.
Help!! Any thoughts would be most gratefully recieved.
Sasha
Sasha
