if using a 120 degree LED bulb, what is the ideal distance to install the GU10 sockets in the ceiling - 1m apart and away from the walls?
Go to a wholesaler with proper plans. They often have tie-ups with lighting designers who can do layouts for you.
What has your architect said about it?
Why not use lights which are actually designed to do the job of lighting up rooms, rather than ones which are designed to not do that?We are building a new house and will soon have to do the ceilings everywhere.
Surely the ideal place for spotlights is where the beam will shine onto the spot you want to light up?if using a 120 degree LED bulb, what is the ideal distance to install the GU10 sockets in the ceiling - 1m apart and away from the walls?
[DISCLAIMER - IHNI] I suspect replay your prejudices to you, like most consultants.[/DISCLAIMER]What does a lighting designer actually do
