Hi all,
Bought a property with a 'working' boiler. No issues other than a little weep which leads to pressure dropping over time. I'm reluctant to take parts out at this stage and was wondering if somebody with knowledge of this boiler an identify the leak from the pictures below.
It looks like it's either from the edge of the exchange or the pump but it's not wet on the forward facing parts. Underneath you can see where the water has been sitting (and rusting) away the plating. Indeed every so often a drop will come down from the lower pump in the middle. That's as much as I can see without taking things apart.
Many thanks! Andrew
http://www.igaro.com/misc/boiler/b1.jpg
http://www.igaro.com/misc/boiler/b2.jpg
http://www.igaro.com/misc/boiler/b3.jpg
Many thanks! Andrew
