hi guys,
first of all, let me thank you for a wonderful forum. I just hope that someone can help me fix my problem.
I have an Ideal Isar HE24 boiler. All has been ok, but the boiler has some water drops weeping around the pink sealant just above the sump. These water drops tend to weep out more when the central heating or hot water is on and i can only assume that its the water pressure thats forcing itself through the sealer
FYI, if your not sure what or where i'm talking about, i can tell you that this is like a pink window seal (like NO MORE NAILS) going around the bottom of the heat exchanger:-
I'm wondering if I can do anything to stop this?
if anyone can pls help me, then i'd be most grateful.
I eagerly look forward to your replies.
Thanks so much
Thanks so much
