last night i remove the head of the diverter and pushed the brass pin in and out it seamed to be free and was not stuck in any one position
i then emptyed/flushed the system refilled and tried again with it
same problem
the pump is roasting and vibrateing like it is working and is not noisey
so i can only asume that the pump is working hot water works fine
but when it go's from CH to DHW there is no noise from the divertor valve head i can only asumme it i quite but in my experince of honeywell 's' and 'y' plan valves they make a wining wee noise so im not sure if its the divetor or the pump is jammed the easy and cheap option ah think would be to change the divetor head
the guy is easy going enough but i runn the risk of looking like a right rip off clown if i charge him 100 quid plus labour for the pump if its not it
as we say in motherwell "its bursting ma heed man"
Sorry mate I meant push pin in while running water to make valve manually. Or if head was in that position removing allows the pin to come out while running tap.
