I'm new to this forum and have read threads on the Ideal boilers but have been unable to find one which helps with the issue I have.
Over the past couple of years a number of parts have been replaced on the system. New pump, thermistor, pcb etc
The problem is the CH does not work.
Turn on a hot tap and the hot water works fine. Try and turn on the CH and it is lifeless. The Diverter valve is not stuck but what I do note is, when you remove the actor and then call for CH there is NO movement there at all. I would have thought you would have heard/seen the movement required to have pressed the valve had it been connected.
With this in mind my thoughts lead me to believe the actuator is at fault, maybe something internally wrong with its wiring. My next step is to call in an electrician to check for power at the actuator conniption. I assume if the CH is being called for there will be power at this point. I also assume, no power here would/might mean a pcb issue
I would be grateful for anyones thoughts/suggestions on the above
Many thanks
Many thanks
