Ideal Iscos m3080
21 Dec 2006
West Midlands
Hi guys,
called out to repair this boiler, would not ignite fault code LF- fault finding pointed to new PCB. Changed PCB (there are 2 grey wires in a terminal block cannot find home for - don't know if this is the problem) but same problem - will not ignite. There is 200v DC at gas valve and all other ignition sequence takes place. Really could do with picking your brains please!!!!!!!!!!!! :?
Give the condensate trap a clean out. They are gets for blocking up and when they do you get LF failure
no biggy its very very comman as the condensate trap on them is pathetic it is
Glad you sorted it
Its also a right bug**r when you hang the boiler, connect jig up and then find the damn rubber condense pipe on top of your toolbox tray :oops:
