Ideal Logic v Logic + v Independant
10 May 2011
West Midlands
Does anyone know what the difference is between the ideal logic, logic+ and independent?
Is one recommended over the other?
Yes, I know about Ideal, however I have use a Independent 24 previous, and have no problems with it, and they are one of then few manufacturers to produce a combi that that can easily be fitting into a standard kitchen unit, although always open to suggestions
ideal independat service kit £177.34 + vat retail
so i would check the cost of other`s how uch it would be for a full service
Why do you think an Intergas HRE would not fit into a kitchen cabinet?
Tony
Thanks for the suggestion. I will have a closer look.
Not sure about the depth, as 240mm for the boiler, but also need to take account of the size of fixing kit A which take it to 335mm - and larger than a standard cupboard. - havnt got space for the robo kit.
OK then perhaps that will not be suitable.
In that case what about a Viessmann 100 as that have a five year warrantee and is seen as quite reliable.
Tony
