IE 7
  • Thread starter Thread starter breezer
  • Start date Start date
Spark123 said:
Mine comes up with a padlock next to the command line at the top.
Thanks for that I had not noticed it there. I was looking for it along the bottom where it used to be with IE6
From the Thomson web site :-
http://www.speedtouch.co.uk/codepages/content.asp?c=96
28/01/2007 IE7 compatibility issue
As a result of changes incorporated in the authentication protocol used in Internet Explorer 7, attempting to log in to a SpeedTouch router will fail.
Note: Users of Internet Explorer 6 or other web browsers such as Firefox or Safari are not affected by this problem.
The following solution is available for users running firmware versions 5.3, 5.4 and 6.1. A permanent fix for the issue will be included in a future release.
From the main Microsoft Windows menu select:
START > Run..
type: cmd [enter]
a black window opens in this window type:
telnet 192.168.1.254 [enter]
enter your username and password set for the router
type the following commands at the routers system prompt:
: system config digestauth=disabled [enter]
: saveall [enter]
: exit [enter]
The settings will remain active until the router is rebooted.
