Guys
This is a really strange one and at the moment I'm stumped. Please post as many answers or suggestions for this as you can.
Electric remote control Velux windows with rain sensors.
Cabled and fitted onto the lighting circuit with a fused switch and access point.
When I power up the velux via the fused switch (i.e. switch it on) the MCB trips.
Three possible scenarios -
cross wire/short
faulty switch
damaged cable
Cable tested fine before everything was sealed by the builders.
Changed the switch 4 times from 3 different manufacturers. Also extractor isolator at the side which is working fine. Disconnected the extractor and re-connected the velux into that switch. Tripped the MCB. Cant be the switch.
Bypassed the switch and powered up from the main CU and the velux works fine.
Re-connected switch. Tried to power up in reverse order - Switch then MCB then main box. As soon as the main box is powerd up the MCB trips.
I am absolutely baffled. The only scenario that works is the direct connecting of the velux to the lighting circuit.
Any ideas?
cross wire/short
faulty switch
damaged cable
Any ideas?
