- Joined
- 19 Apr 2020
- Messages
- 535
- Reaction score
- 2
- Country
If the OP bless him takes the sump plug out and finds the sump thread has pulled out with it
He’ll need a plan B because the car may well be undriveable.
Take it from me, if a suction pump leaves a bit of oil behind it won’t matter at all......use a quality oil and filter and all will be well.
Many diesels now don’t need an oil drop until 18k - if you dare - so an oil change at 5k or whatever must be sheer luxury!
John![]()
Hey John
I am hoping when I take out the plug it will come out easily and not bring the threads out with it. If this happens can a new thread be tapped in ? If not I guess I will be attempting a sump replacement myself at home but I really hope that will not be the case and I hope a new oil drain bolt will suffice.
Out of curiosity how much would a small garage charge labour only to fit the sump ?
I think I will try drain it from the dipstick next week but on the next oil change I want to investigate the sump and see if it is just the bolt that needs replacing. I am not sure it is a problem with just the drain plug as the drain plug was new 1 or 2 oil changes prior to the most recent oil change and it visibly looked ok as far as I remember but it was very tight going back in.
I want to do frequent oil changers oin it at about every 5 - 7 k , especially now it is almost at 200 k, it has around 198,370 miles on the clock right now.
cheers
