Need some guidance on trouble shooting a new issue that has arrisen with my imersion tank.
I have a vented Heatrae Megalife cylinder with twin immersions. Both immersions are hooked up to a Horstman Electronic 7 timeclock, The lower immersion is on the timed output and the upper immersion is on the Boost output. It's a single circuit, no economy 7 wiring.
For the last two days the circuit rcbo has been tripping when the immersion is on. I might get anywhere upto an hour of run time before it trips. initially i thought it was the lower imersion failing, however the circuit still trips when using the upper boost immersion. same behaviour - runs for a while then trips.
Whats the best strategy to troubleshoot and isolate the issue ? I've got test equipment so can do IR testing, trip time testing etc
Thanks.
Thanks.
