    Dismiss Notice
imperial radiators vs metric
Discussion in 'Plumbing and Central Heating' started by andyathlon, 25 Oct 2016.
  1. andyathlon
    andyathlon
    25 Oct 2016
    3
    Thanks Received:
    Country:
    Hi Looking for some comparison of BTU / KW output of imperial radiators vs metric radiators.
    I have 6 radiators all are double panel double fins but are the old style painted steel. Would I see an increase in BTU/KW output by replacing them with the new metric modern ones?
    I used this website http://www.simplifydiy.com/plumbing-and-heating/radiators/power
    and calculated that my radiators were giving out 14850BTU or 4.4KW.
    If I replaced them with new I would get 44775BTU or 13.1KW.
    To me this seems like a massive difference and wasnt sure how to validate this as I could not find any ratings for the old imperial sized radiators.
    Any help or advice is appreciated
    Andy
  2. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,089
    Thanks Received:
    1,092
    Norfolk
    Country:
    If you replace your existing imperial dimension rads with the metric sized equivalents, there will be minor differences in physical size and little difference in output. You may have made a mistake in your calcs.
  3. Sponsored Links
  4. andyathlon
    andyathlon
    25 Oct 2016
    3
    Thanks Received:
    Country:
    Well I assumed that the numbers were off but there is no mistake in the calculations when using that website to work out what I have.
    Are you aware of how I could calculate the actual BTU output of my existing radiators?
  5. JohnD
    JohnD
    15 Nov 2005
    73,404
    Thanks Received:
    4,226
    Crossgates, Europe
    Country:
    Cook Islands
    "If I replaced them with new I would get 44775BTU or 13.1KW."
    please show us the source that says so.
    For sensibility checking, a single rad 600mm high x 1000mm wide should have a nominal output in the region of 1kW
    If you tell us the dimensions of your radiators and, for at least one of them, the claimed heat output from each of your sources, we may see if there is an obvious error.
    I notice that one of your calculations is about three times the other (2.98 approx.)
    Disregarding the position of the decimal point, this is similar to the numbers difference btu/kw, because 1,000 btu is about 0.293kw. Perhaps this is a coincidence.
  6. Sponsored Links
  7. andyathlon
    andyathlon
    25 Oct 2016
    3
    Thanks Received:
    Country:
    HAHAHA I totally see what I have done. So sorry to waste everyones time. I miss read the website and assumed it was in BTUS when it was in Watts.
    Ahh well back to the drawing board on how to heat my house. thanks for the help
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
