Firstly merry Christmas to everyone. I hope you had a good few days rest.
I am installing electronically retractable bollards in my drive before I have the resin bound gravel finish laid.
I dug the hole for the 1st bollard today which I knew had the mains power running nearby. Typically over a 6m wide opening the mains power sits within the 300mm space i needed it not to and 100mm above where I needed it to.. As it stands it will hit the bollard casing by approx. 100mm. Images show where the center line of the 300mm casing will sit and the 2nd image shows where the cable would need to be moved to to miss the casing. The case is cylindrical so the pinch point is at approximately 200mm in. The length of exposed cable is approximately 600mm.
How much persuasion can these cables take? Light ran out before i could safely investigate further but can a cable like this be "nudged" over 100mm?
I realize what this is and have seen 1st hand the consequences of compromising a cable like this so am very mindful that the correct answer is "you should not touch" but in reality is using something to persuade it over 4" a huge risk? I assume UKPN will not be interested in such a job or will charge an arm and a leg for it.
What do people normally do in this very unfortunate by typical luck situation?
If I remove more earth at either end will it give a little more?
NB. The casing encloses all moving parts so there will be nothing "mechanical" coming into contact with the cable.
