    Dismiss Notice
Indesit IDVL75BR tumble dryer not heating
Discussion in 'Appliances' started by cromwell4, 11 Jan 2015.
  1. cromwell4
    cromwell4
    20 Apr 2010
    7
    Thanks Received:
    Cambridgeshire
    Country:
    Hi, I bought brand new Indesit dryer in October. It has stopped heating the air. I believe I may need to reset something. I have removed the back 2 plates but there was nothing underneath. Any ideas?
  2. Sponsored Links
  3. rocks1
    rocks1
    30 Apr 2008
    6,138
    Thanks Received:
    1,041
    Country:
    Why are you playing around with it if it's under gtee.
  4. cromwell4
    cromwell4
    20 Apr 2010
    7
    Thanks Received:
    Cambridgeshire
    Country:
    Point taken. Wasn't sure if this would be covered. I'll call them tomorrow.
  5. rocks1
    rocks1
    30 Apr 2008
    6,138
    Thanks Received:
    1,041
    Country:
    You can reset the stat ,on the top on the heater is two stats one has a pin hole in it. Use a safety pin to reset it.
  6. cromwell4
    cromwell4
    20 Apr 2010
    7
    Thanks Received:
    Cambridgeshire
    Country:
    I was unable to see the stat when I took the covers off.
  7. Sponsored Links
  8. rocks1
    rocks1
    30 Apr 2008
    6,138
    Thanks Received:
    1,041
    Country:
    The only cover is the rear banjo one. Then u will see the coiled heater. Two screws on the rear will release it. Stats on top of that
  9. xr4x4
    xr4x4
    1 Oct 2009
    3,159
    Thanks Received:
    290
    Hampshire
    Country:
    Got the same problem.. Tried above.. Didn't work..
    Gonna have to go through the hassle of a warranty claim..
  10. yardie
    yardie
    20 Oct 2010
    835
    Thanks Received:
    103
    Country:
    If its not heating test the exhaust stat, heater stat/(s) and heating element.
    Check all vents, filters and hoses are clear.
    If those are all ok it could be a faulty timer or pcb.
    What I don't understand is why Argos advertise this has a 'reservoir full' indicator when it is vented and not a condenser dryer? Perhaps you could confirm, a) vented or condenser and b) does it have a reservoir full light.
  11. xr4x4
    xr4x4
    1 Oct 2009
    3,159
    Thanks Received:
    290
    Hampshire
    Country:
    Three stat looking things above heating element, two silver disk, one black plastic one in the middle.
    Tested all for continuity, both sliver disk ones where ok, black plastic one had none, I bypassed this with a link, still no heat.
    I've emailed indesit.
    Edit... Wifey has just told me its now heating....
    :unsure:
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
