Hi Folks, hoping someone can help here....
M/c is an Indesit WI121 and is a year and two weeks old (
typical!-but there is an extended 1yr John Lewis warranty on it so not all bad)
It is accepting programs normally but will only run through the wash cycle. When it gets to the rinse / drain cycles after 30 mins or so, it stops dead and the LED does nothing - so no fault code.
The m/c is full of water, and it's warm, so heater etc is OK, but I have to wait quite some time before it will appear to power up again and I can reset the m/c to run a manual drain or spin.
Opened the pump inspection hole and all seems OK, nothing obviously jamming it / blocking it and impeller looks to be spinning normally. The machine is pumping as I can manually drain it. It's the stopping dead, appearing to cut power and doing nothing after the wash cycle that is puzzling me!
Any ideas / suggestions gratefully received!
baz
baz
