    Dismiss Notice
inhibitor / noise reducer
Discussion in 'Plumbing and Central Heating' started by sanjayp, 23 Nov 2005.
  1. sanjayp
    sanjayp
    16 Nov 2005
    55
    Thanks Received:
    Cambridgeshire
    Country:
    I am shortly having some work done on a couple of radiators which will require a drain down of the CH system. I have a combi boiler Potterton Performa 28i.
    I understand that I have to put some form of protector into the system. I have bought "Fernox Superconcentrate Central Heating Protector" for this. In addition, my boiler often lets out an initial "groan" when it fires. I notice that I can buy something called "boiler noise reducer/silencer" (fernox and sentinel both do this). Might this solve the problem? Is it ok to add both the protector and noise reducer? I presume is it ok to mix products from different companies (for example, I have already bought fernox protector but can add sentinel noise reducer or am I best sticking to fernox for this also)?
    btw. what is meant by an 'inhibitor' and is it the same as "central heating protector"
    thanks
    sanjay
  2. Sponsored Links
  3. sanjayp
    sanjayp
    16 Nov 2005
    55
    Thanks Received:
    Cambridgeshire
    Country:
    Briefly checking the fernox website I see that the generic ceneral heating protector has a feature of "reducing boiler noise". So I guess I nned to know whether there is any point in also using a separate noise reducer. Will it make any difference?
    thanks
    sanjay
  4. JohnD
    JohnD
    15 Nov 2005
    74,232
    Thanks Received:
    4,289
    Crossgates, Europe
    Country:
    Cook Islands
    They may be compatible, but no-one will warrant that, so I'd buy the same brand if I were you.
    I use a boiler noise reducer which is supposed to combat lime scale which is prevalent in my area, it does seem to make a difference.
  5. gazthepottertonengineer
    21 May 2005
    1,294
    Thanks Received:
    134
    Country:
    i dont think the noise your refering too is anything to do with scale or sludge so the fernox boiler silencer would be a waste of money :confused:
    noise is more likely to be problem with O'rings in the diverter valve when its switching over to heating mode ;)
  6. Sponsored Links
  7. sanjayp
    sanjayp
    16 Nov 2005
    55
    Thanks Received:
    Cambridgeshire
    Country:
    If the problem is with the O rings, then can it be rectified or do I have to live with it? Is it likely to be doing any long term damage to the diverter?
    thanks
    sanjay
  8. gazthepottertonengineer
    21 May 2005
    1,294
    Thanks Received:
    134
    Country:
    no its just annoying :confused: change the O'rings and that will sort it ;)
  9. sanjayp
    sanjayp
    16 Nov 2005
    55
    Thanks Received:
    Cambridgeshire
    Country:
    ok, thanks. Since my boiler is still under warranty (till xmas) I rang potterton who will send someone out to have a look at it.
    btw. what causes this sort of problem with the O'ring? The boiler can't be very well designed if this can happen during the first year of its life.
    thanks
    sanjay
  10. gazthepottertonengineer
    21 May 2005
    1,294
    Thanks Received:
    134
    Country:
    i have found that certain types of inhibitor react badly with the O'rings causing them to swell and be oversized :confused:
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
