Install gas hob
8 May 2007
What range of fittings do i need to bring to install a hob. Will probably be using 10mm copper tube. I have heard there are different types connectiuon points to hobs. Please advise on whether fittings are male or female also.
Thanks Michael
Most hobs i've installed come with a 1/2" swivel nut and sometimes they come with 1/2" male to 15mm compression elbow to start you off. After that its up to you, I usually reduce down to 10mm for the last few inches to make it a bit easier and more room. Dont forget your isolation valve. :wink:
