Hi guys,
Refitting my kitchen and need an extractor fan (over hob type).
Was wondering if these normally connect straight into the mains or if they have a standard plug fitting and plug into a socket.
(Obviously going to get a spark in to do it but just want to be a bit informed before I get quotes).
If you look on the pic below you can just about see where the cooker is now (so extractor above it), where the current wall fitted extractor is and just to the right of the cooker on the tiled splashback - where the nearest electric supply is:
View media item 22416
Assuming that the extractor needs connecting direct into the mains, will the spark likely run the cabling from the current fan (above the "to be installed" wall units or up inside the wall from the sockets..... or something completely different?
