Righto,
Basically wanting to install an RCD in a house I've just bought. The CU isn't the most modern but has MCBs, so I can't see the point of replacing it. What I was going to do wa buy an RCD in an enclosure and wire it between the meter and the CU, by diverting the existing meter tails to the RCD and putting in some new tails from the RCD to the CU. I've seen this done before, so assume there is nothing 'illegal' in doing it! Just one question, are there any implications about removing the main fuse (80A) on the incomers prior to the meter? I can't see a way of doing this work without removing it, though!
cheers!
cheers!
