installing dimmer
8 Sep 2007
Yorkshire
Trying to install dimmer in lounge. Currently 2 light are on 1 standard switch. The wiring inside the blue neutrals are joined in a little plastic junction (not sure whats its proper name is) and the live wires go to L1 and L2.
I have bought a single dimmer, and a double dimmer as I\\\'d prefer to control the lights independently. The double I wired the Brown lives to the live connectors top and bottom and the corresponding blue to the ~(with arrow) top and bottom. The lights would not then come on. I have not tried the single dimmer as I was unsure on the wiring. If this is the route I have to take to both neutrals go to the ~ and both lives go to L1. Not tried as I though this would short.
Thanks in advance for any help or advice.
thank your lucky stars it didnt work, it would have gone bang
you seem to be saying you have 2 blue and two brown (since you said the 2 blue are in a connector) is this right?
RULE ONE OF LIGHTING CIRCUITS!!!!!!
Never EVER connect NEUTRALS to LIGHT SWITCHES!!!
Connecting neutrals to light switches will have 2 results:
1. Toasted switches
2. BANG!
You have 2 brown wires: LIVE and SWITCHED LIVE. The switch simply opens and closes a contact between them (or a variac and other sensitive controls in the case of a dimmer)
By connecting live and neutral ACROSS THE SWITCH you have probably fried its SENSITIVE ELECTRONIC innards. :wink:
Given there is only one feed to the 2 lights from this location, if you want to split them onto 2 switches, you will need to do more wiring.
Thanks for the replies.
I have also the single dimmer which I could fit. How would I determine the live and switched live? and to which connectors in the dimmer do they attach?
On a dimmer it doesnt really matter. Convention says the live should go to COM (~) and the switched live to L1 but it'll work either way round.
