Installing downlight over shower. Any reason why not?
9 May 2020
Hi all. New to the forum.
I live in a recently built flat with an en suite bathroom that uses LED downlights (see picture)
As you can see, there's no downlight over the shower, which makes it a bit dark. I'm thinking of installing the missing downlight (to make the square) over the shower. I removed the existing downlights to take a peek into the void to see if there were any obstacles and there are none - no beams, electrics, plumbing, etc.
Needless to say I would get a light with the rights spec for a bathroom and such. However, am I missing something? Is there any reason why I shouldn't do it? It seems so easy that I almost feel like I'm missing something.
In a flat, the ceiling itself is a fire barrier. So you must get a fire- rated downlight. Also get one that complies with Building regs part C To stop moist air bring drawn into the roof void.
Oh yes. Is the ceiling more than 2.25 metres high?
and I assume that you own and do not rent the flat?
Yes. That will be ok. Note you will need a lamp too.
Have a look at the other ones and get the same wattage and colour output or the new one will look out of place.
Check above to make sure there are no restrictions. There may be a reason why there’s no light there!
Look at the other lights and copy how they have dealt with the ceiling insulation.
