Installing dual head shower head mixer
28 Jun 2021
Hi
I want to install dual shower head, haven't bought it yet but ineterested in the screwfix Swirl range link below:
In the more info says product hight 1170mm, the distance from my 15mm H&C water pipes to ceiling is 1270mm, so will have only 100mm space may look odd? May be my pipes were installed higher than usual are at 1200mm from floor in brick tiled wall.
I haven't installed one of these dual showers before, are they height adjustable?
Yes, fit at at any height you like to suit your existing pipework.
I don't think you understood my question. The product height as per screwfix is 1170mm, is this height adjustable, to for example at 1000mm?
The Screwfix comments shows the manufacturers help is worse than useless.
So IMO the best way to find out is to go ask to look at it at a branch.
Can't see how you'd adjust it, short of cutting a section out of the rising pipe and using a coupler to rejoin, which would end up looking a bit odd, if you could even find a suitable thing
Cutting or modifying the pipes would be a messy job, won't go there.
What is the diameter of these chorme pipes?
What space between ceiling and horizontal pipe of the deluge is aesthetically acceptable?
Just wherever it ends up, it should be quite high.
I think my pipes at 12000mm from floor is a but high can't change it, ceiling hight is 2400mm, it won't look nice if too close to ceiling.
Might not be too bad, the separate rain head ones are attached to the ceiling.
