- Joined
- 23 Aug 2021
- Messages
- 11
- Reaction score
- 0
- Country
I've had a Salamander negative head pump installed in the airing cupboard, just above the HWC. The HWC has has an Essex flange with the required anti-gravity loop installed and the cold water tank is about a metre above the pump in the loft. The outputs from the pump go back up into the loft and there is a straight run of about 3m to the en-suite bathroom where it drops down into a Swirl mixer shower.
The issue I'm facing is I get very good flow when it's fully hot or fully cold on the shower mixer, but when trying to get a reasonable temp, the flow starts weakening & getting cooler and I gradually have to move the mixer towards towards the hot till it become warm enough. It'll stay at the correct temp, but the flow is now noticeably weaker.
Having looked around on the internet, I did think it was an issue with the mixer which I taken apart from check the cartridge and it seems to be ok. Strangely, when I take off the shower head from the hose, I get fantastic flow at the right temp coming out of the hose, even when it's up on the shower rail and not on the floor. It's only when I've got the shower head on that the flow is weak. I've tried a couple of other shower heads which I hoped would solve the issue, but haven't found one to completely solve the issue.
I have thought it's perhaps because it's a long run from the pump output to the shower mixer and I don't have an automatic air vent installed at the highest point, but not positive this will solve my issue.
