Installing Ikea kitchen - Advice on cover panel for larder
26 Nov 2017
Hi all,
I am looking for confirmation on how to attach a cover panel to the side of a 220cm tall larder cupboard, between a normal height base unit.
This image shows that you do run a panel the entire height of the larder cupboard, then the worktop and cupboard door of the base unit finish flush against it, but I have seen other images showing something different. Is this the recommended approach?
Thanks!
You choose which you prefer or space dictates. You can use the cover panel cut to match side panel and use it in place of side panel if short of space or use as shown but then other units will look best if matched in style .(For example my drawer unit which has one side exposed has end panels fitted to both sides).
Thanks @foxhole, looks like I have a bit of space to spare so fitted it along the entire length of the larder cupboard. Quite happy with the result.
