Installing laminate flooring up against PVC Door
16 Sep 2017
Looking for a bit of advice.
I have been installing laminate flooring in my livingroom and have become stuck on what to do when I get to my pvc door as pictured.
Should I treat this as a wall and just lay up to the door, my only concern is the beading will not look right when installed as the door protrudes out a bit more than the skirting. What is the standard approach to this?
Should I try cut out some of the PVC and slide the flooring under?
Any advice would be appreciated.
? Why not ? Don’t it loads of times with low doors.
It works out 3mm higher then the Lamainte once down
