Installing Mira flight low profile shower ready
1 Feb 2011
Cardiff
Hi - after some advice on a new shower tray
i want to fit a Mira flight square tray. The instructions say bed on 5:1 cement bed - which is fine.
it’s to be installed on ground floor, concrete but I’ll need to rise it up to install waste. I also need to run a waste pipe under the tray to pick up the washing machine waste.
I’m not sure on the riser kits - I don’t think they look great - but maybe they are better than I imagine? They look like the tray could move/flex?!
what are my options with regards to a plywood riser on a solid base (from 65mm concrete brick for example) with the 5:1 bed on top of this?
cheers
Phil
7 Jan 2007
If its on a concrete floor use breeze blocks cut them to the depth you want minus 10mm for compo on top of the breeze.
Dry fit it and mark through the trap hole to position the waste. Make all your waste connections then fit the tray. Riser kits u/s you'll need trim to Cover around the tray.
4 Oct 2012
East Renfrewshire
Unless you can get a nominal fall on the waste pipe then I would avoid sharing it with the washing machine. If there are any restrictions or issues then the pumped waste water will fill your shower.
Riser kits are lousy things and always end up moving.
Just make sure the base is dead level and solid and the top is very secure into the block so there is no movement later down the line.
