so lets see, he plugs a 3KW fan heater into a double socket, that's 13A.. in every room.. so with 3 rooms he's already overloaded the ring main by 4A and has no more left for the telly, video, computer, Hi-Fi...
heaters of this kind are fine for occasional use, or for 1 room that's maybe got no other form of heating..
if you're after general heating by electric, then you would be better with a dedicated radial for each heater.
it might be worth considering Air Con as these can often be run in heating mode in the winter and will be more efficient than a straight electric heater.. ( you get 3KW of heat out for every 1KW you put in, or there abouts.. )
the added advantage is of course, cooling in the summer as well..
