Is this possible or near insane idea?
I need to install a safety/pir light outside our kitchen extension next to the backdoor.
Inside the kitchen there is a socket close to the backdoor. Could I drill a hole next to it, take a cable outside to the light, but leave a standard plug on the inside? This is so the indoor socket can be used whenever needed and then keep the pir light plugged in when needed (night times mainly).
If the ikea is ok.. can you advice best type of cable to use + use a separate RDC switch on the plug ok?
Many thanks
Many thanks
