installing shower tray in ensuite
3 Aug 2005
Warwickshire
I have a shower tray in the main bathroom which is on adjustable legs with a skirt covering the void.
I am about to install a shower tray in an ensuite and really would like to have the tray on the floor rather than having to step up into the shower. Obvously you need to get to the waste connection. I was planning to tile the floor so an access hatch would not be easy. Can you get a shower tray with a large waste hole that you can access the waste if you do have a problem in the future?
Thanks in advance
Don;t think so.
Raise it and use a shallow trap. :D
Use a trap with a removable center grill so you can clean it.
It is normally a requirement to have a 75mm trap seal on showers; unless you are running the waste into a hopper where the shallow traps comply.
If you run the waste with the correct gradients, use long bends, solvent weld fittings (without excessive solvent) you will not have problems.
Consider the routing of the waste.... Cutting a 3" deep notch in joists to accommodate the pipework is not a good idea.
The joists run across the room so I wont havr to cut a joist I can run the pipe straight out the wall.
