Hi
I have a CCTV recorder PVR that I need to hide in the floor so it isn't stolen if my house is burgled. I have cut away a section of 2 floorboards, screwed them to a piece of MDF, then mounted the PVR on top of the MDF. This works well.
My remaining concern is that if the house is ransacked then it will likely be unplugged, so I would like to install an additional socket under the floor.
It's right by the ring main connection to another socket so it should be fairly straightforward but is there anything else I need to be aware of?
Is it OK to mount the socket on a joist using a regular back box and socket, or should I use an outdoor type socket with a built in RCD? Or something else?
Advice appreciated. Thanks.
