I have been trying to research through forums etc for a while and have still yet to come up with a clear 'best' solution. I appreciate some of this has been asked before by I have some specific questions
I want to internally insulate the external walls in my kitchen (each 7m by 3.5m). The walls are currently dot n dabbed with 12.5mm plasterboard (20 years ago) but these appear not to have adhered well as the wall sounds hollow when tapped. The brick walls have many years of old paint on them so I am looking at mechanical fix solutions.
The 3 solutions I am looking at are:
(1) 2x1 batons at 400mm centres with 50mm Insulated plasterboard mechanically fixed
or
(2) 2x1 batons at 400mm centres with 50mm foil backed insulation mechanically fixed and joints taped with 12.5mm plasterboard mechanically fixed on top
or
(3) 3x2 batons at 400mm centres - in-filled with 50mm rigid foil backed insulation & VCL & plasterboarded on top
Questions:
Are people moving away from using insulated plasterboard? Is this due to higher cost, ease of working, joints in insulation?
Is an air gap required between outer wall and insulation to stop condensation or can the insulation butt up against the wall?
With option 2 above should both the insulation and plasterboard be mechanically fixed?
If I create a stud wall (infilled with insulation) will I get thermal bridging through the studs?
Many Thanks,
or
or
Questions:
Many Thanks,
